在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
芯片精品文章合集(500篇!)    创芯人才网--重磅上线啦!
查看: 3532|回复: 1
为何我的uart 不能接收
发表于 2006-8-25 10:03:57 | 显示全部楼层 |阅读模式
为何我的uart 不能接收
我试着写了一个串口发送和接收的小程序,发现发现过程是好的,可为什么会接到不到呢?感觉上不应该出现这种情况,请大侠帮看看。
#include "xparameters.h"
#include "xstatus.h"
#include "xuartlite_l.h"
/************************** Constant Definitions *****************************/
#define UARTLITE_BASEADDR       XPAR_RS232_UART_BASEADDR
#define TEST_BUFFER_SIZE 16
/************************** Function Prototypes ******************************/
XStatus UartLiteLowLevelExample(Xuint32 UartliteBaseAddress);
/************************** Variable Definitions *****************************/
* The following buffers are used in this example to send and receive data
* with the UART.
Xuint8 SendBuffer[TEST_BUFFER_SIZE]; /* Buffer for Transmitting Data */
Xuint8 RecvBuffer[TEST_BUFFER_SIZE]; /* Buffer for Receiving Data */
int main(void)
    XStatus Status;
     * Run the UartLite Low level example , specify the BaseAddress that is
     * generated in xparameters.h
    Status = UartLiteLowLevelExample(UARTLITE_BASEADDR);
    if (Status != XST_SUCCESS)
        return XST_FAILURE;
    return XST_SUCCESS;
    int Index;
     * Initialize the send buffer bytes with a pattern to send and the
     * the receive buffer bytes to zero
    for (Index = 0; Index < TEST_BUFFER_SIZE; Index++)
        SendBuffer[Index] = Index + 'B';
        RecvBuffer[Index] = 0;
     * Send the entire transmit buffer.,此处是工作的
        XUartLite_SendByte(UartliteBaseAddress, SendBuffer[Index]);
        printf("%d***",SendBuffer[Index]);
     * Receive the entire buffer's worth. Note that the RecvByte function
     * blocks waiting for a character.此外为什么没有接收???
        RecvBuffer[Index] = XUartLite_RecvByte(UartliteBaseAddress);
        printf("%d###",RecvBuffer[Index]);
     * Check the receive buffer data against the send buffer and verify the
     * data was correctly received
        if (SendBuffer[Index] != RecvBuffer[Index])
            return XST_FAILURE;
    return XST_SUCCESS;
发表于 2006-8-28 17:43:29 | 显示全部楼层
RE:
好久没有接触“direct hardware”了,下面是我的拙见:
首先申明,我不太了解“xuartlite_l.h”, 呵呵
你应该做的是一个自发自收的程序,发送显然是可行的,因为你可以选择对发送内容不处理(应该在发送中断里)。但是接收语句“RecvBuffer[Index] = XUartLite_RecvByte(UartliteBaseAddress); ” 的执行应该在你的接收中断向量中。正常的情况是:每接收到一个byte的信息,执行接收语句,上面的程序不满足这一点,你的程序顺序执行发收最多只能收到最后一个byte。或者根本没有
正确的做法是把接收处理和接收中断向量关联起来
GMT+8, 2024-3-29 22:49 , Processed in 0.042872 second(s), 10 queries , Gzip On, Redis On.
