NI LabVIEW 2009 v9.0 Control Design and Simulation Module
Withthe NI LabVIEW Control Design and Simulation Module, you can analyzeopen-loop model behavior, design closed-loop controllers, simulateonline and offline systems, and conduct physical implementations.
Createmodels from first principles using transfer function, state-space, orzero-pole-gain representation. With time and frequency analysis tools,such as time step response or Bode plot, you can interactively analyzeopen- and closed-loop behavior. Use built-in tools for both multipleinput, multiple output (MIMO) and single input, single output (SISO)systems and take advantage of simulation capabilities to verify linearand nonlinear system dynamics. You can also use built-in tools toconvert your models developed in The MathWorks, Inc. Simulink®software to work with LabVIEW.
In addition, you can expandLabVIEW Control Design and Simulation usability with other NI softwaretools. For example, you can use the LabVIEW System IdentificationToolkit to find empirical models from real plant stimulus-responseinformation and the LabVIEW Statechart Module for event-based controldesign or event-driven simulation. You can deploy dynamic systems toreal-time hardware targets with the LabVIEW Real-Time Module for rapidcontrol prototyping and hardware-in-the-loop applications.
Install notes:
1) unpack
2) burn / mount
3) install
4) crack dir
Download from HotFile
http://hotfile.com/dl/11293061/15b28c9/cdslv2k9.part1.rar.html
http://hotfile.com/dl/11293054/daef24e/cdslv2k9.part2.rar.html
http://hotfile.com/dl/11293057/10dfa76/cdslv2k9.part3.rar.html
http://hotfile.com/dl/11293055/603f2ef/cdslv2k9.part4.rar.html
OR
Download from FileFactory
http://www.filefactory.com/file/ah5d7f9/n/cdslv2k9_part1_rar/
http://www.filefactory.com/file/ah5d7gb/n/cdslv2k9_part2_rar/
http://www.filefactory.com/file/ah5d7g6/n/cdslv2k9_part3_rar/
http://www.filefactory.com/file/ah5d7f7/n/cdslv2k9_part4_rar/
Links are interchangeable
TheNI LabVIEW Desktop Execution Trace Toolkit helps you trace theexecution of LabVIEW VIs on a Windows target during run time to detectand locate problems in code that could affect performance or causeunexpected behavior. It provides a chronological view of VI events,queue operations, reference leaks, memory allocation, unhandled errors,and subVI execution. With this toolkit, you can programmaticallygenerate user-defined events from the block diagram of a LabVIEWapplication.
In addition, you can use this toolkit to parse thetrace data with custom filters or export the data to a spreadsheet fordocumentation. By highlighting individual events, you can obtainadditional information such as the call chain and cpu number. You alsocan double-click traced events to highlight the corresponding object onthe block diagram.
Dynamic code analysis is an importantpractice for demonstrating correct behavior and debugging complexsoftware. You can configure the LabVIEW Desktop Execution Trace Toolkitto monitor execution of VIs on a local machine or remotely over anetwork. In addition to VIs in the development environment, you can usethe toolkit to profile debuggable executables and shared libraries.
Install notes:
1) unpack
2) burn / mount
3) install
4) crack dir
http://hotfile.com/dl/11293056/fba97f1/detlv2k9.part1.rar.html
http://hotfile.com/dl/11293060/7549846/detlv2k9.part2.rar.html
http://hotfile.com/dl/11293058/e70bd64/detlv2k9.part3.rar.html
http://hotfile.com/dl/11293059/48bd12c/detlv2k9.part4.rar.html
OR
http://www.filefactory.com/file/ah5d7g3/n/detlv2k9_part1_rar/
http://www.filefactory.com/file/ah5d7g4/n/detlv2k9_part2_rar/
http://www.filefactory.com/file/ah5d7g1/n/detlv2k9_part3_rar/
http://www.filefactory.com/file/ah5d7f5/n/detlv2k9_part4_rar/
TheNI LabVIEW Datalogging and Supervisory Control (DSC) Module is theideal LabVIEW add-on for developing your HMI/SCADA orhigh-channel-count data-logging applications. With the NI LabVIEW DSCModule, you can interactively develop a distributed monitoring andcontrol system with tags ranging from a few dozen to tens of thousands.It includes tools for logging data to a networked historical database,real-time and historical trending, managing alarms and events,networking LabVIEW Real-Time targets and OPC devices into one completesystem, and adding security to user interfaces.
http://hotfile.com/dl/11293091/973ce4d/dsclv2k9.part1.rar.html
http://hotfile.com/dl/11293096/3c78049/dsclv2k9.part2.rar.html
http://hotfile.com/dl/11293101/8ec56f3/dsclv2k9.part3.rar.html
http://hotfile.com/dl/11293104/89335da/dsclv2k9.part4.rar.html
http://hotfile.com/dl/11293112/b8431bd/dsclv2k9.part5.rar.html
http://hotfile.com/dl/11293120/bbdd367/dsclv2k9.part6.rar.html
http://hotfile.com/dl/11293131/4f868a4/dsclv2k9.part7.rar.html
OR
http://www.filefactory.com/file/ah5d7gd/n/dsclv2k9_part1_rar/
http://www.filefactory.com/file/ah5d7g9/n/dsclv2k9_part2_rar/
http://www.filefactory.com/file/ah5d7hg/n/dsclv2k9_part3_rar/
http://www.filefactory.com/file/ah5d7f6/n/dsclv2k9_part4_rar/
http://www.filefactory.com/file/ah5d7gh/n/dsclv2k9_part5_rar/
http://www.filefactory.com/file/ah5d7f8/n/dsclv2k9_part6_rar/
http://www.filefactory.com/file/ah5d7f4/n/dsclv2k9_part7_rar
Usethe LabVIEW Microprocessor SDK along with a third-party toolchain andan embedded OS to target the 32-bit processor of your choice. With theLabVIEW Microprocessor SDK, you can easily incorporate legacy C code aswell as Analog, digital, and communications I/O drivers throughspecialized VIs. This module features several example targets forpopular processor architectures including PowerPC, ARM, TI C6x, andx86, and ColdFire.
Install notes:
1) unpack
2) burn / mount
3) install
4) crack dir
http://hotfile.com/dl/11293243/c17411e/sdklv2k9.part1.rar.html
http://hotfile.com/dl/11293248/1e8e5a3/sdklv2k9.part2.rar.html
http://hotfile.com/dl/11293257/135777e/sdklv2k9.part3.rar.html
http://hotfile.com/dl/11293259/503f2f8/sdklv2k9.part4.rar.html
http://hotfile.com/dl/11293264/3f4b6ac/sdklv2k9.part5.rar.html
http://hotfile.com/dl/11293270/b8ae8e4/sdklv2k9.part6.rar.html
OR
http://www.filefactory.com/file/ah5d70g/n/sdklv2k9_part1_rar/
http://www.filefactory.com/file/ah5d70f/n/sdklv2k9_part2_rar/
http://www.filefactory.com/file/ah5d71g/n/sdklv2k9_part3_rar/
http://www.filefactory.com/file/ah5d707/n/sdklv2k9_part4_rar/
http://www.filefactory.com/file/ah5d703/n/sdklv2k9_part5_rar/
http://www.filefactory.com/file/ah5d70b/n/sdklv2k9_part6_rar/
@ Ahmad_K
here is the medicine
oops, i forgot pw completely:
www.sonsivri.com
(getting forgetful probably the side effects of doctorate degree!)
RS links:
http://rapidshare.com/files/274516220/emeien_13.nilv2k9x86_uds.part01.rar
http://rapidshare.com/files/274515977/emeien_13.nilv2k9x86_uds.part02.rar
http://rapidshare.com/files/274515888/emeien_13.nilv2k9x86_uds.part03.rar
http://rapidshare.com/files/274515821/emeien_13.nilv2k9x86_uds.part04.rar
http://rapidshare.com/files/274517708/emeien_13.nilv2k9x86_uds.part05.rar
http://rapidshare.com/files/274518631/emeien_13.nilv2k9x86_uds.part06.rar
http://rapidshare.com/files/274516848/emeien_13.nilv2k9x86_uds.part07.rar
http://rapidshare.com/files/274518037/emeien_13.nilv2k9x86_uds.part08.rar
http://rapidshare.com/files/274517053/emeien_13.nilv2k9x86_uds.part09.rar
pw: ut@updatesofts.com
NI LabVIEW 2009 v9.0 (x86/x64)
Size: 867MB + 936MB
Formore than 20 years, NI LabVIEW graphical programming has revolutionizedthe development of test, measurement, and control applications.Regardless of experience, engineers and scientists can rapidly andcost-effectively interface with measurement and control hardware,analyze data, share results, and distribute systems.
Install notes:
1) unpack
2) burn / mount
3) install
4) crack dir
Download Links:
x86
http://hotfile.com/dl/11293176/a48ae10/nilv2k9x86.part01.rar.html
http://hotfile.com/dl/11293178/e30817b/nilv2k9x86.part02.rar.html
http://hotfile.com/dl/11293191/ebb922e/nilv2k9x86.part03.rar.html
http://hotfile.com/dl/11293192/dff1cc3/nilv2k9x86.part04.rar.html
http://hotfile.com/dl/11293218/37f3939/nilv2k9x86.part05.rar.html
http://hotfile.com/dl/11293223/65d7c7b/nilv2k9x86.part06.rar.html
http://hotfile.com/dl/11293235/0de875d/nilv2k9x86.part07.rar.html
http://hotfile.com/dl/11293237/d53011e/nilv2k9x86.part08.rar.html
http://hotfile.com/dl/11293239/85c05ce/nilv2k9x86.part09.rar.html
x64
http://hotfile.com/dl/11293141/796bb61/nilv2k9x64.part01.rar.html
http://hotfile.com/dl/11293142/986bf8f/nilv2k9x64.part02.rar.html
http://hotfile.com/dl/11293151/5a9e70f/nilv2k9x64.part03.rar.html
http://hotfile.com/dl/11293152/b6a7489/nilv2k9x64.part04.rar.html
http://hotfile.com/dl/11293156/3002ef7/nilv2k9x64.part05.rar.html
http://hotfile.com/dl/11293157/6cfc424/nilv2k9x64.part06.rar.html
http://hotfile.com/dl/11293161/27967e6/nilv2k9x64.part07.rar.html
http://hotfile.com/dl/11293163/b178f9a/nilv2k9x64.part08.rar.html
http://hotfile.com/dl/11293164/ee15c38/nilv2k9x64.part09.rar.html
http://hotfile.com/dl/11293167/8c28479/nilv2k9x64.part10.rar.html |
