在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 10441|回复: 66
Principles of Signal Detection and Parameter Estimation
发表于 2009-7-31 17:12:57 | 显示全部楼层 |阅读模式
  • Publisher:   Springer
  • Number Of Pages:   644
  • Publication Date:   2008-07-07
  • ISBN-10 / ASIN:   0387765425
  • ISBN-13 / EAN:   9780387765426
  • Binding:   Hardcover
Product Description:
This new textbook is for contemporary signal detection and parameter estimation courses offered at the advanced undergraduate and graduate levels. It presents a unified treatment of detection problems arising in radar/sonar signal processing and modern digital communication systems. The material is comprehensive in scope and addresses signal processing and communication applications with an emphasis on fundamental principles. In addition to standard topics normally covered in such a course, the author incorporates recent advances, such as the asymptotic performance of detectors, sequential detection, generalized likelihood ratio tests (GLRTs), robust detection, the detection of Gaussian signals in noise, the expectation maximization algorithm, and the detection of Markov chain signals. Numerous examples and detailed derivations along with homework problems following each chapter are included
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
1.1 Book Organization . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
1.2 Complementary Readings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
References . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Part I Foundations
2 Binary and M-ary Hypothesis Testing . . . . . . . . . . . . . . . . . . . . . 15
2.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
2.2 Bayesian Binary Hypothesis Testing . . . . . . . . . . . . . . . . . . . . . . . 16
2.3 Sufficient Statistics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25
2.4 Receiver Operating Characteristic . . . . . . . . . . . . . . . . . . . . . . . . . 27
2.4.1 Neyman-Pearson Tests . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29
2.4.2 ROC Properties . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 32
2.5 Minimax Hypothesis Testing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 39
2.6 Gaussian Detection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 49
2.6.1 Known Signals in Gaussian Noise . . . . . . . . . . . . . . . . . . . . 50
2.6.2 Detection of a Zero-Mean Gaussian Signal in Noise . . . . 51
2.7 M-ary Hypothesis Testing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 52
2.7.1 Bayesian M-ary Tests . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 52
2.7.2 Sufficient Statistics for M-ary Tests. . . . . . . . . . . . . . . . . . 56
2.7.3 Performance Analysis . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 59
2.7.4 Bounds Based on Pairwise Error Probability . . . . . . . . . . 62
2.8 Bibliographical Notes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 63
2.9 Problems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 63
References . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 71
3 Tests with Repeated Observations . . . . . . . . . . . . . . . . . . . . . . . . . 73
3.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 73
3.2 Asymptotic Performance of Likelihood Ratio Tests . . . . . . . . . . . 74
3.3 Bayesian Sequential Hypothesis Testing . . . . . . . . . . . . . . . . . . . . 88
3.4 Sequential Probability Ratio Tests . . . . . . . . . . . . . . . . . . . . . . . . . 94
3.5 Optimality of SPRTs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 100
3.6 Bibliographical Notes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 102
3.7 Problems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 102
3.A. Proof of Cram´er’s Theorem . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 108
References . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 111
4 Parameter Estimation Theory . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 113
4.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 113
4.2 Bayesian Estimation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 114
4.2.1 Optimum Bayesian Estimator . . . . . . . . . . . . . . . . . . . . . . . 117
4.2.2 Properties of the MSE Estimator . . . . . . . . . . . . . . . . . . . . 123
4.3 Linear Least-squares Estimation . . . . . . . . . . . . . . . . . . . . . . . . . . . 125
4.4 Estimation of Nonrandom Parameters . . . . . . . . . . . . . . . . . . . . . . 131
4.4.1 Bias . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 133
4.4.2 Sufficient Statistic . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 136
4.4.3 Cram´er-Rao Lower Bound . . . . . . . . . . . . . . . . . . . . . . . . . . 138
4.4.4 Uniform Minimum Variance Unbiased Estimates . . . . . . 150
4.5 Asymptotic Behavior of ML Estimates . . . . . . . . . . . . . . . . . . . . . 154
4.5.1 Consistency . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 154
4.5.2 Asymptotic Distribution of the ML Estimate . . . . . . . . . 157
4.6 Bibliographical Notes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 159
4.7 Problems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 159
4.A. Derivation of the RBLS Theorem . . . . . . . . . . . . . . . . . . . . . . . . . . 166
References . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 167
5 Composite Hypothesis Testing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 169
5.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 169
5.2 Uniformly Most Powerful Tests . . . . . . . . . . . . . . . . . . . . . . . . . . . . 170
5.3 Invariant Tests . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 177
5.4 Linear Detection with Interfering Sources . . . . . . . . . . . . . . . . . . . 194
5.5 Generalized Likelihood Ratio Tests . . . . . . . . . . . . . . . . . . . . . . . . 197
5.6 Asymptotic Optimality of the GLRT . . . . . . . . . . . . . . . . . . . . . . . 204
5.6.1 Multinomial Distributions . . . . . . . . . . . . . . . . . . . . . . . . . . 205
5.6.2 Exponential Families . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 216
5.7 Bibliographical Notes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 221
5.8 Problems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 222
5.A. Proof of Sanov’s Theorem . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 231
References . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 232
6 Robust Detection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 235
6.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 235
6.2 Measures of Model Proximity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 236
6.3 Robust Hypothesis Testing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 239
6.3.1 Robust Bayesian and NP Tests . . . . . . . . . . . . . . . . . . . . . . 239
6.3.2 Clipped LR Tests . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 241
6.4 Asymptotic Robustness . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 250
6.4.1 Least Favorable Densities . . . . . . . . . . . . . . . . . . . . . . . . . . . 251
6.4.2 Robust Asymptotic Test . . . . . . . . . . . . . . . . . . . . . . . . . . . 254
6.5 Robust Signal Detection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 257
6.5.1 Least-Favorable Densities . . . . . . . . . . . . . . . . . . . . . . . . . . . 258
6.5.2 Receiver Structure . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 261
6.6 Bibliographical Notes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 264
6.7 Problems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 265
References . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 275
Part II Gaussian Detection
7 Karhunen-Lo`eve Expansion of Gaussian Processes . . . . . . . . . 279
7.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 279
7.2 Orthonormal Expansions of Deterministic Signals . . . . . . . . . . . . 280
7.3 Eigenfunction Expansion of Covariance Kernels . . . . . . . . . . . . . 284
7.3.1 Properties of Covariance Kernels . . . . . . . . . . . . . . . . . . . . 285
7.3.2 Decomposition of Covariance Matrices/Kernels . . . . . . . . 289
7.4 Differential Characterization of the Eigenfunctions . . . . . . . . . . . 294
7.4.1 Gaussian Reciprocal Processes . . . . . . . . . . . . . . . . . . . . . . 294
7.4.2 Partially Observed Gaussian Reciprocal/Markov
Processes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 307
7.4.3 Rational Stationary Gaussian Processes . . . . . . . . . . . . . . 310
7.5 Karhunen-Lo`eve Decomposition . . . . . . . . . . . . . . . . . . . . . . . . . . . 313
7.6 Asymptotic Expansion of Stationary Gaussian Processes . . . . . . 315
7.7 Bibliographical Notes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 316
7.8 Problems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 317
References . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 324
8 Detection of Known Signals in Gaussian Noise . . . . . . . . . . . . . 327
8.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 327
8.2 Binary Detection of Known Signals in WGN . . . . . . . . . . . . . . . . 328
8.2.1 Detection of a Single Signal . . . . . . . . . . . . . . . . . . . . . . . . . 328
8.2.2 General Binary Detection Problem . . . . . . . . . . . . . . . . . . 332
8.3 M-ary Detection of Known Signals in WGN. . . . . . . . . . . . . . . . . 338
8.4 Detection of Known Signals in Colored Gaussian Noise . . . . . . . 344
8.4.1 Singular and Nonsingular CT Detection . . . . . . . . . . . . . . 346
8.4.2 Generalized Matched Filter Implementation . . . . . . . . . . 348
8.4.3 Computation of the Distorted Signal g(t) . . . . . . . . . . . . . 352
8.4.4 Noise Whitening Receiver . . . . . . . . . . . . . . . . . . . . . . . . . . 356
8.5 Bibliographical Notes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 362
XVI Contents
8.6 Problems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 362
References . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 368
9 Detection of Signals with Unknown Parameters . . . . . . . . . . . . 371
9.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 371
9.2 Detection of Signals with Unknown Phase . . . . . . . . . . . . . . . . . . 372
9.2.1 Signal Space Representation . . . . . . . . . . . . . . . . . . . . . . . . 373
9.2.2 Bayesian Formulation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 374
9.2.3 GLR Test . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 377
9.2.4 Detector Implementation . . . . . . . . . . . . . . . . . . . . . . . . . . . 378
9.3 Detection of DPSK Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 381
9.4 Detection of Signals with Unknown Amplitude
and Phase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 386
9.4.1 Bayesian Formulation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 387
9.4.2 GLR Test . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 389
9.5 Detection with Arbitrary Unknown Parameters . . . . . . . . . . . . . . 389
9.6 Waveform Parameter Estimation . . . . . . . . . . . . . . . . . . . . . . . . . . 395
9.7 Detection of Radar Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 402
9.7.1 Equivalent Baseband Detection Problem . . . . . . . . . . . . . 403
9.7.2 Cram´er-Rao Bound . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 406
9.7.3 ML Estimates and GLR Detector . . . . . . . . . . . . . . . . . . . 409
9.7.4 Ambiguity Function Properties . . . . . . . . . . . . . . . . . . . . . . 412
9.8 Bibliographical Notes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 420
9.9 Problems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 421
References . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 431
10 Detection of Gaussian Signals in WGN . . . . . . . . . . . . . . . . . . . . 433
10.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 433
10.2 Noncausal Receiver . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 434
10.2.1 Receiver Structure . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 435
10.2.2 Smoother Implementation . . . . . . . . . . . . . . . . . . . . . . . . . . 442
10.3 Causal Receiver . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 448
10.4 Asymptotic Stationary Gaussian Test Performance . . . . . . . . . . 456
10.4.1 Asymptotic Equivalence of Toeplitz and Circulant
Matrices . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 457
10.4.2 Mean-square Convergence of ST . . . . . . . . . . . . . . . . . . . . . 459
10.4.3 Large Deviations Analysis of the LRT. . . . . . . . . . . . . . . . 461
10.4.4 Detection in WGN . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 466
10.5 Bibliographical Notes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 473
10.6 Problems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 473
References . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 480
Contents XVII
11 EM Estimation and Detection of Gaussian Signals with
Unknown Parameters . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 483
11.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 483
11.2 Gaussian Signal of Unknown Amplitude in WGN of Unknown
Power . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 485
11.3 EM Parameter Estimation Method . . . . . . . . . . . . . . . . . . . . . . . . 486
11.3.1 Motonicity Property . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 488
11.3.2 Example . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 489
11.3.3 Convergence Rate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 492
11.3.4 Large-Sample Covariance Matrix . . . . . . . . . . . . . . . . . . . . 498
11.4 Parameter Estimation of Hidden Gauss-Markov Models . . . . . . 500
11.4.1 EM iteration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 501
11.4.2 Double-sweep smoother . . . . . . . . . . . . . . . . . . . . . . . . . . . . 504
11.4.3 Example . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 507
11.5 GLRT Implementation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 511
11.6 Bibliographical Notes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 515
11.7 Problems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 516
References . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 522
Part III Markov Chain Detection
12 Detection of Markov Chains with Known Parameters . . . . . . 527
12.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 527
12.2 Detection of Completely Observed Markov Chains . . . . . . . . . . . 528
12.2.1 Notation and Background . . . . . . . . . . . . . . . . . . . . . . . . . . 528
12.2.2 Binary Hypothesis Testing . . . . . . . . . . . . . . . . . . . . . . . . . . 533
12.2.3 Asymptotic Performance . . . . . . . . . . . . . . . . . . . . . . . . . . . 534
12.3 Detection of Partially Observed Markov Chains . . . . . . . . . . . . . 543
12.3.1 MAP Sequence Detection. . . . . . . . . . . . . . . . . . . . . . . . . . . 546
12.3.2 Pointwise MAP Detection . . . . . . . . . . . . . . . . . . . . . . . . . . 563
12.4 Example: Channel Equalization . . . . . . . . . . . . . . . . . . . . . . . . . . . 571
12.4.1 Markov Chain Model . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 571
12.4.2 Performance Analysis . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 574
12.5 Bibliographical Notes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 585
12.6 Problems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 585
References . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 589
13 Detection of Markov Chains with Unknown Parameters . . . 593
13.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 593
13.2 GLR Detector . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 595
13.2.1 Model . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 595
13.2.2 GLR Test . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 597
13.3 Per Survivor Processing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 599
13.3.1 Path Extension . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 599
XVIII Contents
13.3.2 Parameter Vector Update . . . . . . . . . . . . . . . . . . . . . . . . . . 599
13.4 EM Detector . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 605
13.4.1 Forward-backward EM . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 608
13.4.2 EM Viterbi Detector . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 613
13.5 Example: Blind Equalization . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 619
13.5.1 Convergence Analysis . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 621
13.5.2 Convergence Rate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 623
13.6 Bibliographical Notes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 628
13.7 Problems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 628
References . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 631
Index . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 633
PSDPE.part1.rar
4.77 MB, 下载次数: 348 , 下载积分: 资产 -3 信元, 下载支出 3 信元
PSDPE.part2.rar
1.28 MB, 下载次数: 332 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-7-31 18:18:00 | 显示全部楼层
非常棒的一本书籍
谢谢楼主的分享
发表于 2009-7-31 18:20:42 | 显示全部楼层
通信理论的必备基础之一
谢谢分享
发表于 2009-8-1 10:14:34 | 显示全部楼层
好书,谢谢分享。
发表于 2009-8-1 18:11:22 | 显示全部楼层
非常好的一本书,信号检测与参数估计,是通信基础理论
非常好的一本书,信号检测与参数估计,是通信基础理论,但是很难学
发表于 2009-8-2 10:07:07 | 显示全部楼层
好书啊,谢谢分享啊
发表于 2009-8-2 10:50:13 | 显示全部楼层
look!look!
发表于 2009-8-3 07:40:05 | 显示全部楼层
看起来很不错的一本书,感谢分享。
发表于 2009-8-5 20:56:21 | 显示全部楼层
thanks
thanks a lot.
发表于 2009-8-25 20:43:09 | 显示全部楼层
GMT+8, 2024-3-28 18:31 , Processed in 0.032242 second(s), 10 queries , Gzip On, Redis On.
