在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 7727|回复: 8
[求助]Cadence IC610启动后的问题和无法使用帮助文档!
发表于 2009-7-15 13:58:32 | 显示全部楼层 |阅读模式
看了很多安装说明后,终于在openSUSE11.1安装上了Cadence IC610,启动$lmli,然后$icfb&后, 出现如下提示:
libxcb: WARNING! Program tries to lock an already locked connection,
        which indicates a programming error.
        There will be no further warnings about this issue.
libxcb: WARNING! Program tries to unlock a connection without having acquired
        a lock first, which indicates a programming error.
请问这是怎么回事呀,怎么解决呢?谢谢!
已经可以启动了,不过virtuoso@6.1.0 log-/../CDS.log主界面下面显示:
COPYRIGHT © 1992-2006  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
          © 1992-2006  UNIX SYSTEMS Laboratories INC.,
                         Reproduced with permission.
This Cadence Design Systems program and online documentation are
proprietary/confidential information and may be disclosed/used only
as authorized in a license agreement controlling such use and disclosure.
          RESTRICTED RIGHTS NOTICE (SHORT FORM)
Use/reproduction/disclosure is subject to restriction
set forth at FAR 1252.227-19 or its equivalent.
Program:        @(#)$CDS: virtuoso.exe version 6.1.0 10/10/2006 14:09 (cds126047) $
Sub version:        sub-version IC6.1.0.243 (32-bit addresses)
Loading geView.cxt
Loading LVS.cxt
Loading layerProc.cxt
Loading xlUI.cxt
Loading auCore.cxt
Loading schView.cxt
Loading selectSv.cxt
Loading vhdl.cxt
Loading seismic.cxt
Loading ams.cxt
END OF SITE CUSTOMIZATION
*WARNING* obShowTag for tool "text", tag "hiNoHelp" (version "") failed, status 20 = obcServerCantStart
*Warning* No help found for help symbol hiNoHelp
已经在.bashrc加入了下面的语句:
alias lmli='/home/eda/ic610/tools/bin/lmgrd -c /home/eda/ic610/share/license/license.dat'
export OA_HOME=/home/eda/ic610/OA
export CDS_ROOT=/home/eda/ic610
export MMSIM_ROOT=/home/eda/mmsim61
export CDS_LIC_FILE=5280@***
export LM_LICENSE_FILE=$CDS_ROOT/share/license/license.dat
export CDS_Netlisting_Mode=Analog
export PATH=$MMSIM_ROOT/tools/binMMSIM_ROOT/tools/spectre/binCDS_ROOT/tools/binCDS_ROOT/tools/dfII/bin:$PATH
export MOZILLA_HOME=/usr/bin/netscape
其中,***是用 hostname 命令查到的主机名
在主界面中点击help下面的Cadence Documentation,出现help提示框
Some Cadence online documentation files are missing or can not opened duo to an error.
To start the Cadence documentation system, type cdsdoc at a system prompt.
同时在终端下出现如下:
/home/eda/ic610/tools/cdsdoc/bin/obServer: error while loading sharedlibraries: libnsl.so.1: cannot open shared object file: No such file ordirectory
obApi: unable to contact /home/eda/ic610/tools/bin/obServer.
在终端系统提示符下,运行如下命令,结果如下:
***@***:~> cdsdoc
/home/eda/mmsim61/tools/jre/bin/java: error while loading sharedlibraries: libpthread.so.0: cannot open shared object file: No suchfile or directory
***@***:~> cdsbook
/home/eda/ic610/tools/jre/bin/java: error while loading sharedlibraries: libpthread.so.0: cannot open shared object file: No suchfile or directory
virtuoso@6.1.0主界面命令行输入命令和响应如下:
cdsdoc
*Error* toplevel: undefined variable - cdsdoc
docbook
*Error* toplevel: undefined variable - docbook
opendoc
*Error* toplevel: undefined variable - opendoc
cdsbook
*Error* toplevel: undefined variable - cdsbook
哪位大虾帮忙解决一下!谢谢!
[ 本帖最后由 lishyg 于 2009-7-16 15:19 编辑 ]
发表于 2009-12-19 23:50:18 | 显示全部楼层
请问楼主,以下不能启动的问题是如何解觉的?
发表于 2009-12-24 06:48:30 | 显示全部楼层
no path set to help file
发表于 2010-12-23 16:41:22 | 显示全部楼层
install  libxp.rpm 就好了~~ ( or xplib.rpm ? )
发表于 2011-7-27 22:04:37 | 显示全部楼层
回复 1# lishyg
    我也遇到了,不过解决了,请查看 http://www.chiplayout.net/820.html
发表于 2012-5-4 23:13:17 | 显示全部楼层
不知如何解决啊??
发表于 2012-8-3 10:20:54 | 显示全部楼层
libxcb:warning!的解决方法在哪里?
发表于 2014-9-25 10:11:36 | 显示全部楼层
回复 5# loongsky
   请问你的linux系统是什么啊?
发表于 2018-3-16 14:54:05 | 显示全部楼层
謝謝分享  大推  感恩  thx
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-24 15:56 , Processed in 0.031089 second(s), 8 queries , Gzip On, Redis On.
