在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 5246|回复: 20
震撼!!!!IEEE Standard SystemC® Language Reference Manual
发表于 2009-3-10 07:37:18 | 显示全部楼层 |阅读模式
CONTENTS
1. Overview............................................................................................................................................. 1
1.1 Scope........................................................................................................................................... 1
1.2 Purpose........................................................................................................................................ 1
1.3 Subsets ........................................................................................................................................ 1
1.4 Relationship with C++ ................................................................................................................. 1
1.5 Guidance for readers .................................................................................................................... 2
2. References........................................................................................................................................... 3
3. Terminology and conventions used in this standard............................................................................ 4
3.1 Terminology................................................................................................................................ 4
3.1.1 Shall, should, may, can................................................................................................. 4
3.1.2 Implementation, application......................................................................................... 4
3.1.3 Call, called from, derived from .................................................................................... 4
3.1.4 Specific technical terms ............................................................................................... 4
3.2 Syntactical conventions ............................................................................................................... 6
3.2.1 Implementation-defined............................................................................................... 6
3.2.2 Disabled ....................................................................................................................... 6
3.2.3 Ellipsis (...)................................................................................................................... 6
3.2.4 Class names.................................................................................................................. 6
3.2.5 Embolded text .............................................................................................................. 7
3.3 Semantic conventions .................................................................................................................. 7
3.3.1 Class definitions and the inheritance hierarchy ........................................................... 7
3.3.2 Function definitions and side-effects ........................................................................... 7
3.3.3 Functions whose return type is a reference or a pointer............................................... 7
3.3.4 Namespaces and internal naming................................................................................. 9
3.3.5 Non-compliant applications and errors ........................................................................ 9
3.4 Notes and examples ................................................................................................................... 10
4. Elaboration and simulation semantics ............................................................................................... 11
4.1 Elaboration................................................................................................................................ 11
4.1.1 Instantiation ............................................................................................................... 11
4.1.2 Process macros........................................................................................................... 13
4.1.3 Port binding and export binding ................................................................................ 13
4.1.4 Setting the time resolution ......................................................................................... 14
4.2 Simulation................................................................................................................................. 14
4.2.1 The scheduling algorithm .......................................................................................... 15
4.2.2 Cycles in the scheduling algorithm............................................................................ 17
4.3 Running elaboration and simulation .......................................................................................... 18
4.3.1 Function declarations................................................................................................. 18
4.3.2 Function sc_elab_and_sim......................................................................................... 18
4.3.3 Functions sc_argc and sc_argv .................................................................................. 19
4.3.4 Running under application control using functions sc_main and sc_start................. 19
4.3.5 Running under control of the kernel .......................................................................... 20
4.4 Elaboration and simulation callbacks ........................................................................................ 20
4.4.1 before_end_of_elaboration ........................................................................................ 21
4.4.2 end_of_elaboration .................................................................................................... 22
4.4.3 start_of_simulation .................................................................................................... 23
1666-2005.pdf
2.24 MB, 下载次数: 129 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-5-11 23:45:01 | 显示全部楼层
正寻找中 !!!!
发表于 2010-6-7 16:14:39 | 显示全部楼层
good!!
发表于 2010-6-21 11:38:10 | 显示全部楼层
support
发表于 2010-6-21 14:41:15 | 显示全部楼层
好书!谢谢,分享!
发表于 2010-6-21 18:14:02 | 显示全部楼层
very good
发表于 2010-8-9 20:41:20 | 显示全部楼层
very good
发表于 2010-9-8 17:43:36 | 显示全部楼层
good book
发表于 2010-9-9 13:21:12 | 显示全部楼层
谢谢分享
发表于 2010-9-9 15:14:12 | 显示全部楼层
这个一定要下来看看
GMT+8, 2024-3-29 14:14 , Processed in 0.031610 second(s), 9 queries , Gzip On, Redis On.
