在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
EETOP诚邀模拟IC相关培训讲师 创芯人才网--重磅上线啦!
查看: 10796|回复: 28
BIAS CURRENT GENERATORS WITH WIDE DYNAMIC RANGE
发表于 2008-12-31 14:45:55 | 显示全部楼层 |阅读模式
BIAS CURRENT GENERATORS WITH WIDE DYNAMIC RANGE.pdf
1.14 MB, 下载次数: 145 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-12-31 14:46:08 | 显示全部楼层
Tobi Delbrück1, André van Schaik2
 楼主| 发表于 2008-12-31 14:46:22 | 显示全部楼层
ABSTRACT
Mixed-signal or analog chips often require a wide range of biasing currents that are independent of process and supply voltage and that are proportional to absolute temperature. This paper describes CMOS circuits that we use to generate a set of fixed bias currents typically spanning six decades at room temperature down to a few times the transistor off-current. A bootstrapped current reference with a new startup and power-control mechanism generates a master current, which is successively divided by a current splitter to generate the desired reference currents. These references are nondestructively copied to form the chip’s biases. Measurements of behavior, including temperature effects from 1.6μ and 0.35μ implementations, are presented and nonidealities are investigated. Temperature dependence of the transistor off-current is investigated because it determines the lower limit for generated currents. Readers are directed to a design kit that allows easy generation of the complete layout for a bias generator with a set of desired currents for scalable MOSIS CMOS processes.
Key Words: bias current generator, current reference, current splitter, current divider, PTAT
发表于 2009-4-27 16:37:47 | 显示全部楼层
学习了。。。
发表于 2009-8-24 17:49:56 | 显示全部楼层
Good!!!!!!!!!!!!!!!!
发表于 2009-8-24 20:32:09 | 显示全部楼层
感谢感谢...........
发表于 2009-8-26 10:00:12 | 显示全部楼层
goood
发表于 2009-9-28 14:31:29 | 显示全部楼层
先下下来看看
发表于 2010-1-23 02:32:12 | 显示全部楼层
7# craigwang kankan
发表于 2010-1-23 15:46:52 | 显示全部楼层
good  look
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-17 06:53 , Processed in 0.028645 second(s), 6 queries , Gzip On, Redis On.
