楼主: nemovon
闭环运放的仿真问题
发表于 2009-3-18 07:13:40 | 显示全部楼层
Ususally, you can break the loop at the high impedance node and estimate the C in this node, then add AC source and put the C back in the loop for AC simulation. You will get teh same frequency response(FB=1). However, at close loop, you have to know which freq. you are using and see how open loop BW/Gain will impact teh close loop.
发表于 2009-3-21 00:02:55 | 显示全部楼层
也想知道。。。。。。 等高人回答。
发表于 2009-4-5 00:25:49 | 显示全部楼层
主要与系统的建立与稳定时间有关。
发表于 2011-7-8 16:46:30 | 显示全部楼层
反馈那里讲了一点
发表于 2011-9-20 23:34:38 | 显示全部楼层
学习了
GMT+8, 2025-11-2 15:17 , Processed in 0.013515 second(s), 3 queries , Gzip On, Redis On.
