在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 26894|回复: 98
后端高手是什么样子?
发表于 2008-11-6 09:21:43 | 显示全部楼层 |阅读模式
非常想见识见识
发表于 2008-11-6 09:33:59 | 显示全部楼层
据说后端设计比前端拿钱多?
 楼主| 发表于 2008-11-6 09:40:32 | 显示全部楼层
恩,做过前端的转后端理解上会轻松些
发表于 2008-11-6 09:45:59 | 显示全部楼层
Sorry I can't key in Simplified Chinese
You may refer to TSMC reference flows, that is most advanced ASIC design flow
Be able to handle
10+ millions instances SOC designs
hierarchical planning and analysis
DFT knowledge and deal with boundary scan, core test, memory bist, compression scan chains
DFM knowledge and deal with metal density, dummy metal fill, virtual CMP to timing, lithography & routing
handles Low Power , power off, voltage frequency scheduling with multi-corner, multi-mode
handles Signal integrity, crosstalk & electron migration issues
handles power spec. to floorplan, i.e. voltage drop, power noise, SSO, decoupling cap, well tap etc.
handles on-chip variations, with gated clocks, and state-retantion filpflops
handles special circuits, such as analog, high frequency or RF, DDR, differential pair signal
If you are good at above topics, you may start to implement TCL or C (with APIs) to deal your own back-end problems, refer to most CAD labs research topics in the university.
发表于 2008-11-14 10:59:14 | 显示全部楼层
楼上的真是牛人!!!
发表于 2008-11-14 20:04:15 | 显示全部楼层
后端的方向是什么呢?
发表于 2008-11-14 22:58:00 | 显示全部楼层
4楼回复真牛~
发表于 2008-11-20 21:36:54 | 显示全部楼层
it is so hard
发表于 2008-11-21 13:17:06 | 显示全部楼层
4楼  的     佩服
发表于 2008-11-25 07:13:45 | 显示全部楼层
4楼的确实很牛,
他说的9条正是我的努力方向,
目前,能做到5条,
努力
GMT+8, 2024-4-25 13:42 , Processed in 0.028040 second(s), 8 queries , Gzip On, Redis On.
