在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 10781|回复: 83
2008springer-Logic Synthesis for Compositional Microprogram Control Units
发表于 2008-7-19 09:46:23 | 显示全部楼层 |阅读模式
[size=120%]Logic Synthesis for Compositional Microprogram Control Units (Lecture Notes in Electrical Engineering)
By Alexander Barkalov, Larysa Titarenko
Publisher: Springer
Number Of Pages: 272
Publication Date: 2008-08-01
ISBN-10 / ASIN: 3540692835
ISBN-13 / EAN: 9783540692836
Binding: Hardcover
Product Description:
The control unit is one of the most important parts of any digital system. As a rule, control units have an irregular structure, which makes the processing of their logic circuits design very sophisticated. One possible way to optimise such characteristics as the size or performance of control units is to adapt their structures to the particular properties of interpreted control algorithms. In this book control algorithms are represented by the linear graph-schemes of algorithms (GSA), where the number of operator vertices is not less than 75% of the total number of all algorithm vertices. A special class of control units named as compositional microprogram control units (CMCU) is proposed as the best way for interpretation of linear control algorithms. The CMCU includes a finite state machine, which addresses microinstructions of interpreted microprogram, and a microprogram control unit including control memory, which keeps only microoperations of initial GSA. The microprogram control unit uses the principle of natural addressing of microinstructions. Organization of the control unit proposed in the book increases regularity of the circuit, because the system of microoperations is implemented using standard blocks, such as PROM or RAM. At the same time, an irregular part of the system described by means of Boolean functions is reduced. It permits a decrease in the total number of logical elements (PAL, GAL, PLA, FPGA) in comparison with other models of finite state machines. The main goal of all proposed methods is reduction of the number of field-programmable logic devices used for implementation of logic circuit of the addressing FSM.
This book will be interesting and useful for students and postgraduates in the area of Computer Science and for designers of modern digital devices. Compositional microprogram control units enlarge the class of models applied for implementation of control units with modern field-programmable logic devices.
[ 本帖最后由 woainio 于 2008-7-19 09:48 编辑 ]
abbr_13dfb4b181cd86041f49c8a9ec49af2b.pdf
3.44 MB, 下载次数: 369 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-7-19 09:53:13 | 显示全部楼层
Thank you!
发表于 2008-7-19 11:08:32 | 显示全部楼层
thanks !!
发表于 2008-7-19 12:13:11 | 显示全部楼层
找这些东西不容易啊,哈哈
发表于 2008-7-19 14:42:13 | 显示全部楼层
xiexie
发表于 2008-7-19 15:20:25 | 显示全部楼层
good,book,control unit is important part of a design
发表于 2008-7-19 15:29:02 | 显示全部楼层
好书,多谢了。
发表于 2008-7-19 16:17:05 | 显示全部楼层
many thanks..
发表于 2008-7-19 16:18:15 | 显示全部楼层
找这些东西不容易啊,哈哈
发表于 2008-7-19 16:20:42 | 显示全部楼层
xiexie!!!!!!!!!!!1
GMT+8, 2024-3-29 14:15 , Processed in 0.031093 second(s), 9 queries , Gzip On, Redis On.
