The heart of the XLR™ 732 processor consists of an innovative set of XLR cores enabling up to 32 threads or virtual cpus (vCPUs™) in a single chip. The XLR architecture is built around eight XLR processor-enhanced mips64® compatible cores implementing fine-grained, 4-way multithreading combined with multi-level hierarchy of caches, autonomous accelerators, and point-to-point interconnects for data and message transfers.
The interconnects’ full-speed operation augment application scalability and closely integrate the high performance main memory controllers, level-2 caches, 10Gbps accelerated security operations, and accelerated networking interfaces to deliver a processing solution running at frequencies of 800MHz – 1.2GHz optimized for maximum throughput and workload efficiency.
RMI XLR 732 Highlights:
- Operating Frequency 800MHz – 1.2GHz
- 8 Cores with 32 Threads (vCPUs™)
- 2MB of Banked 8-way L2 Caches
- Four Autonomous Security Acceleration Engines (SAEs) with 10Gbps capacity
- 4 x 36bit (144 bit) DDR I/II at 800MHz
- 2 x 10GE/SPI 4.2
- 4 x 1GEs
- 1605 BGA Package
