在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 73107|回复: 426
MINDSHARE系列经典书籍(PCI,ISA,80486,USB1.1,USB2.0……)
发表于 2008-4-13 14:59:38 | 显示全部楼层 |阅读模式
第一本《PCI System Architecture (PC System Architecture)
Book Description
PCI System Architecture is a detailed and comprehensive guide to the Peripheral Component Interconnect (PCI) Bus Specification, Intel's technology for fast communication between peripheral devices and the computer processor.
This new edition has been thoroughly updated, reorganized, and expanded to cover the PCI Local Bus Specification version 2.2 and other recent developments, including the new PCI Hot-Plug Specification,
changes to the PCI-to-PCI Bridge Architecture Specification, revisions to the PCI Bus Power Management Interface Specification, and the new features of the PCI BIOS Specification.
This book provides clear and concise explanations of the relationship of PCI to the rest of the system and PCI fundamentals, including commands, read and write transfers, memory and I/O addressing, error handling, interrupts, and configuration transactions and registers. In addition, you will find specific
information on such key topics as-
Hot-Plug Specification Power management CompactPCI The 64-bit PCI Extension 66 MHz PCI Implementation Expansion ROMs PCI-to-PCI Bridge and the PCI BIOS Add-in cards and connectors Bus arbitration Reflected-wave switching Early transaction end Fast back-to-back and stepping
Changes from PCI 2.1 to PCI 2.2 and changes from PCI-to-PCI Bridge Specification 1.0 to 1.1 are visibly highlighted throughout the book so that those familiar with the previous versions can quickly get a handle on new features and functions.
Anyone who designs or tests hardware or software involving the PCI bus will find PCI System Architecture, Fourth Edition a valuable resource for understanding and working with this important technology.
The PC System Architecture Series is a crisply written and comprehensive set of guides to the most important PC hardware standards. Each title explains from a programmers perspective the architecture, features, and operations of systems built using one particular type of chip or hardware specification.
Synopsis
PCI System Architecture is a detailed and comprehensive guide to the Peripheral Component Interconnect (PCI) Bus Specification, Intel's technology for fast communication between peripheral devices and the computer processor. This new edition has been thoroughly updated, reorganized, and expanded to cover the PCI Local Bus Specification version 2.2 and other recent developments, including the new PCI Hot-Plug Specification, changes to the PCI-to-PCI Bridge Architecture Specification, revisions to the PCI Bus Power Management Interface Specification, and the new features of the PCI BIOS Specification. This book provides clear and concise explanations of the relationship of PCI to the rest of the system and PCI fundamentals, including commands, read and write transfers, memory and I/O addressing, error handling, interrupts, and configuration transactions and registers. In addition, you will find specific information on such key topics as: *Hot-Plug Specification *Power management *CompactPCI *The 64-bit PCI Extension *66 MHz PCI Implementation *Expansion ROMs *PCI-to-PCI Bridge and the PCI BIOS *Add-in cards and connectors *Bus arbitration *Reflected-wave switching *Early transaction end *Fast back-to-back and stepping Changes from PCI 2.1 to PCI 2.2 and changes from PCI-to-PCI Bridge Specification 1.0 to 1.1 are visibly highlighted throughout the book so that those familiar with the previous versions can quickly get a handle on new features and functions. Anyone who designs or tests hardware or software involving the PCI bus will find PCI System Architecture, Fourth Edition a valuable resource for understanding and working with this important technology. The PC System Architecture Series is a crisply written and comprehensive set of guides to the most important PC hardware standards. Each title explains from a programmers perspective the architecture, features, and operations of systems built using one particular type of chip or hardware specification.
有朋友说PCI的附件有问题,今晚查了,的确有问题,很抱歉!不过下面的文件没有问题,放心下载……
[ 本帖最后由 icie 于 2008-4-14 21:44 编辑 ]
 楼主| 发表于 2008-4-13 17:02:31 | 显示全部楼层
ISA System Architecture (Mindshare PC System Architecture)
Book Description
If you design or test hardware or software that involves ISA, ISA System Architecture is an essential, time-saving tool.
The PC System Architecture Series is a crisply written and comprehensive set of guides to the most important PC hardware standards. Each title explains from a programmer's perspective the architecture, features, and operations of systems built using one particular type of chip or hardware specification.
I SA System Architecture describes the hardware architecture of ISA (Industry Standard Architecture), providing a clear, concise explanation of an ISA system in detail. The authors provide a comprehensive treatment of the bus including-
bus cycles
addressing
I/O
RAM, ROM, and cache memory
cache architectures
decode and reset logic
interrupts
system kernel
bus mastering
DMA
RTC and configuration RAM
Synopsis
*ISA System Architecture describes the hardware architecture of ISA (Industry Standard Architecture), providing a clear, concise explanation of an ISA system in detail. The authors provide a comprehensive treatment of the bus including: **-bus cycles *-addressing *-I/O *-RAM, ROM, and cache memory *-cache architectures *-decode and reset logic *-interrupts *-system kernel *-bus mastering *-DMA *-RTC and configuration RAM If you design or test hardware or software that involves ISA, ISA System Architecture is an essential, time-saving tool. The PC System Architecture Series is a crisply written and comprehensive set of guides to the most important PC hardware standards. Each title explains from a programmer's perspective the architecture, features, and operations of systems built using one particular type of chip or hardware specification.
[ 本帖最后由 icie 于 2008-4-13 17:30 编辑 ]
Addison Wesley - MindShare.ISA System Architecture.part1.rar
3.81 MB, 下载次数: 527 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Addison Wesley - MindShare.ISA System Architecture.part2.rar
3.81 MB, 下载次数: 572 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Addison Wesley - MindShare.ISA System Architecture.part3.rar
3.81 MB, 下载次数: 435 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Addison Wesley - MindShare.ISA System Architecture.part4.rar
60 KB, 下载次数: 334 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-4-13 17:37:29 | 显示全部楼层
EISA System Architecture (PC System Architecture, Vol 2)
Product Description
Synopsis
The Extension to Industry Standard Architecture (EISA) standard specifies a means of designing hardware that handles the internal communications and data exchange within a personal computer, and is specifically designed for data communications using 32-bit technology. This book details the difference between EISA and ISA specifications and describes the EISA bus structure, bus masters and slaves, bus arbitration, EISA interrupt handling and other areas.
Addison Wesley - Mindshare - Eisa System Arcitecture, 2Nd Ed.pdf
2.67 MB, 下载次数: 500 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-4-13 17:53:01 | 显示全部楼层
80486 System Architecture (PC System Architecture)
Product Description
Synopsis
80486 System Architecture describes the hardware architecture of PC products using the Intel family of 80486 chips, providing a clear, concise explanation of the 80486 processor's relationship to the rest of the system. The author provides a comprehensive treatment of the processor including: -80486 microarchitecture and its functional units -internal and external caches -hardware interface -SL technology features -instructions new to the 80486 -the register set -486/487SX processors -486DX2 processors -486DX2 write-back enhanced processor -486DX4 processors -implementation-specific issues -main memory subsystem design -OverDrive processors If you design or test hardware or software that involves 486 processors, 80486 System Architecture is an essential, time-saving tool.The PC System Architecture Series is a crisply written and comprehensive set of guides to the most important PC hardware standards. Each title explains from a programmer's perspective the architecture, features, and operations of systems built using one particular type of chip or hardware specification.The PC System Architecture Series features step-by-step descriptions and instructions and accessible illustrations that enable a wide range of readers to easily understand difficult hardware topics. The authors, expert hardware training consultants for clients including IBM, Intel, Compaq, and Dell, have mastered the art of pinpointing and succinctly explaining just the critical information that PC programmers, software and hardware designers, and engineers need to know and leaving out the rest. The result is an exciting series of books that will enable readers of a wide range of backgrounds to make immediate gains in programming productivity.
(Ebook - English) Mindshare Inc , 80486 System Architecture, 3Rd Edition.rar
3.74 MB, 下载次数: 577 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-4-13 18:03:15 | 显示全部楼层
Universal Serial Business System Architecture (PC System Architecture)
Product Description
Book Description
With USB 2.0, the USB standard for PC peripheral connectivity delivers up to 40 times the speed of USB 1.1 -- plus many other extensions, clarifications, and reliability improvements. Now's the time for professional engineers working with PC hardware and peripherals to master USB 2.0 -- and this is the book. The latest in MindShare's world-class PC System Architecture Series, Universal Serial Bus System Architecture, Second Edition teaches engineers everything they need to know to deliver reliable, cost-effective USB 2.0 hardware and software. It covers every key aspect of USB 2.0 product design, including the USB 2.0 protocol, signaling environment, electrical specifications, hardware/software interaction, and more. It has been thoroughly updated to reflect all key changes since USB 1.0. It also contains detailed new coverage of USB 2.0 device classes, legacy support, and Microsoft's implementation of USB host software and class drivers. For all peripheral developers, computer hardware and software design engineers, and other programmers working with Intel-standard PC environments. --This text refers to the Paperback edition.
Synopsis
*Universal Serial Bus System Architecture provides an in-depth discussion of USB and is based on the 1.0 version of the Universal Serial Bus specification. It focuses on the USB protocol, signaling environment, and electrical specifications, along with the hardware/software interaction required to configure and access USB devices. Although this book does not focus on writing USB device drivers, it does contain useful background information that aids in understanding the USB software environment. Key topics include: **-Differential signaling environment. *-Device configuration. *-Suspend/resume operations. *-Device descriptors. *-Device requests (commands). *-Transfer mechanisms. *-USB transaction protocols. *-Bus-powered devices. *-Self-powered devices. *-Host controller designs (UHC and OHC). *-Error detection and handling. *-Device class definitions. If you design or test hardware or software that involves USB, Universal Serial Bus System Architecture is an essential, time-saving tool. The PC System Architecture Series is a crisply written and comprehensive set of guides to the most important PC hardware standards.Each title is designed to illustrate the relationship between the software and hardware and explains thoroughly the architecture, features, and operations of systems built using one particular type of chip or hardware specification. MindShare Inc. is one of the leading technical training companies in the computer industry, providing innovative courses for dozens of companies, including Intel, IBM, and Compaq. Don Anderson passes on his wealth of experience in digital electronics and computer design by training engineers, programmers, and technicians for MindShare.
[ 本帖最后由 icie 于 2008-4-13 18:24 编辑 ]
USB System Architecture - Mindshare.part1.rar
3.81 MB, 下载次数: 1131 , 下载积分: 资产 -2 信元, 下载支出 2 信元
USB System Architecture - Mindshare.part2.rar
3.81 MB, 下载次数: 865 , 下载积分: 资产 -2 信元, 下载支出 2 信元
USB System Architecture - Mindshare.part3.rar
3.64 MB, 下载次数: 1155 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-4-13 18:13:25 | 显示全部楼层
many thanks
 楼主| 发表于 2008-4-13 18:37:16 | 显示全部楼层
Universal Serial Bus System Architecture, 2nd Edition
Product Description
Book Description
Synopsis
USB System Architecture (USB 2.0), MindShare (ebook-pdf).zip
3.97 MB, 下载次数: 1347 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-4-13 18:48:37 | 显示全部楼层
HyperTransport System Architecture (PC System Architecture Series)
Product Description
Book Description
Important book with no competition based on a successful course from Mindshare.
HyperTransport is a new bus that replaces one specific functionality of the PCI bus, chipset interconnect, a high-speed link between the memory and IO controller chips.
Anyone who needs information on HyperTransport architecture either needs to pour through specifications or get this book.
Put this where the other Mindshare books sell. PCI was originally designed to be used in a wide range of systems from notebooks to high-end servers. There are now a wide range of new buses being developed to replace PCI, which enable cost-savings, performance enhancement, and specialized features. HyperTransport is a new bus that deals specifically with chipset interconnect, the high-speed link between the memory and IO controller chips. HyperTransport Architecture allows hardware and low-level software designers, engineers, and technicians to get up to speed quickly on this new bus protocol, without having to wade through specifications and white papers. The book organizes topics in a logical, tutorial format which quickly guides the reader through the major features of the specification. Numerous diagrams and examples reduce the more complicated concepts to manageable proportions and allow the reader to see the important relationships along the way.
MindShare, Inc., is one of the leading technical training companies in the hardware industry, providing innovative courses for dozens of companies including IBM, Intel, and Compaq.
Synopsis
[ 本帖最后由 icie 于 2008-4-13 18:53 编辑 ]
Addison-Wesley - Mindshare, Inc - Hypertransport System Architecture - 2003.part1.rar
3.81 MB, 下载次数: 536 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Addison-Wesley - Mindshare, Inc - Hypertransport System Architecture - 2003.part2.rar
2.53 MB, 下载次数: 439 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-4-13 18:57:20 | 显示全部楼层
PCI Express System Architecture (Mindshare PC System Architecture)
Product Description
Book Description
Mindshare and best selling author Ed Solari, join forces to present a book on the newest bus architecture, PCI Express.
PCI EXPRESS is considered to be the most general purpose bus so it should appeal to a wide audience in this arena.
Today's buses are becoming more specialized to meet the needs of the particular system applications, building the need for this book.
Mindshare and their only competitor in this space (Solari) team up in this new book.
Synopsis
"We have always recommended these books to our customers and even our own engineers for developing a better understanding of technologies and specifications. We find the latest PCI Express book from MindShare to have the same content and high quality as all the others." -Nader Saleh, CEO/President, Catalyst Enterprises, Inc. PCI Express is the third-generation Peripheral Component Inter-connect technology for a wide range of systems and peripheral devices. Incorporating recent advances in high-speed, point-to-point interconnects, PCI Express provides significantly higher performance, reliability, and enhanced capabilities-at a lower cost-than the previous PCI and PCI-X standards. Therefore, anyone working on next-generation PC systems, BIOS and device driver development, and peripheral device design will need to have a thorough understanding of PCI Express. PCI Express System Architecture provides an in-depth description and comprehensive reference to the PCI Express standard. The book contains information needed for design, verification, and test, as well as background information essential for writing low-level BIOS and device drivers.In addition, it offers valuable insight into the technology's evolution and cutting-edge features. Following an overview of the PCI Express architecture, the book moves on to cover transaction protocols, the physical/electrical layer, power management, configuration, and more. Specific topics covered include: *Split transaction protocol *Packet format and definition, including use of each field *ACK/NAK protocol *Traffic Class and Virtual Channel applications and use *Flow control initialization and operation *Error checking mechanisms and reporting options *Switch design issues *Advanced Power Management mechanisms and use *Active State Link power management *Hot Plug design and operation *Message transactions *Physical layer functions *Electrical signaling characteristics and issues *PCI Express enumeration procedures *Configuration register definitions Thoughtfully organized, featuring a plethora of illustrations, and comprehensive in scope, PCI Express System Architecture is an essential resource for anyone working with this important technology.MindShare's PC System Architecture Series is a crisply written and comprehensive set of guides to the most important PC hardware standards. Books in the series are intended for use by hardware and software designers, programmers, and support personnel. 0321156307B08262003
附件在第11楼
[ 本帖最后由 icie 于 2008-4-13 22:05 编辑 ]
发表于 2008-4-13 19:16:55 | 显示全部楼层
ddddddddddddddddddddddddddddddddddddddddddddd
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-20 09:39 , Processed in 0.043467 second(s), 8 queries , Gzip On, Redis On.
