在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
芯片精品文章合集(500篇!)    创芯人才网--重磅上线啦!
查看: 2180|回复: 1
简单排序 代码求助
发表于 2008-3-26 09:10:53 | 显示全部楼层 |阅读模式
有谁帮我看看这个程序吗
我想输入一些数字 然后输入0就结束
然后把这些数字进行排序 然后输出
但是程序好像有问题 谁能帮我调试一下
.data
entry: .word 0, 0, 0, 0, 0, 0, 0, 0;
.main:
la $a0, entry
add $a1, $a0, $0
add $a2, $a0, $0                                #save the adress of a0
add $s3, $ra, $0                                #save $ra
entryloop:
                addi $v0, 0, 5
                syscall                                #input int
                beq $v0, $0, entryexit                #if input = 0 stop input
                sw $v0, 0($a0)                        #save input to $a0
                addi $a0, $a0, 4                #increase $a0
                j entryloop
entryexit:         lw $s0, 0($a1)                        #read first int in the array
                beq $s0, 0, output                #0 is the end of array
                jal sort                        #call the sort function
                addi $a1, $a1, 4                #increase a1
                j entryexit
output:                lw $a0, 0($a2)                        #read first int in the array
                beq $a0, 0, exit                #if it is 0 then exit
                addi $v0, $0, 1
                syscall
                addi $a0, $0, ' '
                addi $v0, $0, 11
                syscall                                #output the int
                addi $a2, $a2, 4                #increase a2, set the next int as the first int of the array
                j output
exit:                add $ra, $s3, $0                #restore ra
                jr $ra
sort:                                                #sort function
                lw $t0, 0($a1)                        #read first input
compareloop:        lw $t1, 0($a1)                        #compare loop
                beq $t1, 0, exitsort                #0 is the end of array
                slt $t5, $t1, $t0                #compare the int with first int in the array
                beq $t5, 0, pass                #if the int have been read is bigger than first int, pass switch.
                addi $t3, $t0, $0
                addi $t0, $t1, $0
                addi $t1, $t0, $0                #these three line switch t1, t0 if t1 is samller
pass:                addi $a1, $a1, 4                #increase a1
                j compareloop
exitsort:        jr $ra
发表于 2009-5-31 18:01:27 | 显示全部楼层
谢谢共享!
GMT+8, 2024-3-29 20:12 , Processed in 0.040789 second(s), 11 queries , Gzip On, Redis On.
