查看: 14074|回复: 17
自动化专业英语
发表于 2007-12-31 21:39:22 | 显示全部楼层 |阅读模式
Lesson 1 Analog Amplifiers
At the most basic level, a signal amplifier does exactly what you expect – it makes a signal
bigger! However, the way in which it is done does vary with the design of the actual amplifier,
the type of signal, and the reason why we want to enlarge the signal. [1] We can illustrate this by
considering the common example of a “Hi-Fi” audio system.
In a typical modern Hi-Fi: system, the signals will come from a unit like a CD player, FM
tuner, or a Tape/Minidisk unit. The signals they produce have typical levels of the order of
100 mV or so when the music is moderately loud. This is a reasonably large voltage, easy to
detect with something like an oscilloscope or a voltmeter. However, the actual power levels of
these signals are quite modest. Typically, these sources can only provide currents of a few
milliamps, which by P=VI means powers of just a few milliwatts. A typical loudspeaker will
require between a few Watts and perhaps over 100 Watts to produce loud sound. Hence we will
require some form of Power Amplifier (PA) to “boost” the signal power level from the source
and make it big enough to play the music.
Fig. 1.1 shows four examples of simple analog amplifier stages using various types of
device. In each case the a.c. voltage gain will usually be approximated by
Fig. 1.1 Examples of voltage amplifiers
Av≈-R1/R2 (1-1)
provided that the actual device has an inherent gain large enough to be controlled by the resistor
values chosen.Note the negative sign in expression 1-1 which indicates that the examples all
invert the signal pattern when amplifying. [2] In practice, gains of the order of up to hundred are
possible from simple circuits like this, although it is usually a good idea to keep the voltage gain
below this. Note also that vacuum state devices tend to be called “valves” in the UK and “tubes”
in the USA.
自动化专业英语
·2·
·2·
Many practical amplifiers chain together a series of analog amplifier stages to obtain a high
overall voltage gain. For example, a PA system might start with voltages of the order of 0.1 mV
from microphones, and boost this to perhaps 10 to 100 V to drive loudspeakers. This requires an
overall voltage gain of 109, so a number of voltage gain stages will be required.
In many cases we wish to amplify the current signal level as well as the voltage. The
example we can consider here is the signal required to drive the loudspeakers in a “Hi-Fi” system.
These will tend to have a typical input impedance of the order of 8 Ohms. So to drive, say, 100
Watts into such a loudspeaker load we have to simultaneously provide a voltage of 28 Vrms and
3.5 Arms. Taking the example of a microphone as an initial source again a typical source
impedance will be around 100 Ohms. Hence the microphone will provide just 1 nA when
producing 0.1 mV. This means that to take this and drive 100 W into a loudspeaker the amplifier
system must amplify the signal current by a factor of over 109 at the same time as boosting the
voltage by a similar amount. [3] This means that the overall power gain required is 1018 – i.e. 180
dB!
This high overall power gain is one reason it is common to spread the amplifying function
into separately boxed pre- and power-amplifiers. The signal levels inside power amplifiers are so
much larger than these weak inputs that even the slightest ‘leakage’ from the output back to the
input may cause problems. By putting the high-power (high current) and low power sections in
different boxes we can help protect the input signals from harm.
In practice, many devices which require high currents and powers tend to work on the basis
that it is the signal voltage which determines the level of response, and they then draw the current
they need in order to work. [4] For example, it is the convention with loudspeakers that the
volume of the sound should be set by the voltage applied to the speaker. Despite this, most
loudspeakers have an efficiency (the effectiveness with which electrical power is converted into
acoustical power) which is highly frequency dependent. To a large extent this arises as a natural
consequence of the physical properties of loudspeakers. We won’t worry about the details here,
but as a result a loudspeaker’s input impedance usually varies in quite a complicated manner with
the frequency. (Sometimes also with the input level.)
Fig. 1.2 shows a typical example. In this case, the loudspeaker has an impedance of around
12 Ohms at 150 Hz and 5 Ohms at 1 kHz. So over twice the current will be required to play the
same output level at 1 kHz than is required at 150 Hz. The power amplifier has no way to “know
in advance” what kind of loudspeaker you will use, so simply adopts the convention of asserting
a voltage level to indicate the required signal level at each frequency in the signal and supplying
whatever current the loudspeaker then requires.
This kind of behavior is quite common in electronic systems. It means that, in information
terms, the signal pattern is determined by the way the voltage varies with time, and ideally the
current required is then drawn. Although the above is based on a high-power example, a similar
situation can arise when a sensor is able to generate a voltage in response to an input stimulus but
can only supply a very limited current. In these situations we require either a current amplifier or
·3·
·3·
a buffer. These devices are quite similar, and in each case we are using some form of gain device
and circuit to increase the signal current level. However, a current amplifier always tries to
multiply the current by a set amount. Hence it is similar in action to a voltage amplifier which
always tries to multiply the signal current by a set amount. The buffer differs from the current
amplifier as it sets out to provide whatever current level is demanded from it in order to maintain
the signal voltage told to assert. Hence it will have a higher current gain when connected to a
more demanding load.
Fig 1.2 Impedance properties of a typical “8 Ohms” loudspeaker
New Words and Phrases
1. analog [5AnElC^] n. 类似物,相似体,模拟量
adj. 模拟的
2. amplifier [5Ampli7faiE] n. [电工]扩音器,放大器
3. illustrate [5ilEstreit] vt. 举例说明,阐明,图解,加插图于
vi. 举例
4. audio [5C:diEu] adj. 音频的,声频的,声音的
n. 音响,声音信号
5. Hi-Fi [5hai5fai] n. hi-fis(收音机、录音机等)具有高保真度
abbr. (略语)高保真(High-Fidelity)
6. fidelity [fi5deliti] n. 忠实,诚实,忠诚,(收音机,录音设备等的)
逼真度,保真度
7. minidisk [5minidisk] n. 小型磁盘
8. approximate [E5prCksimeit] adj. 近似的,大约的
vt., vi. (常与to 连用)近似,接近
9. provided that 假如,倘若,如果,在……的条件下
10. of the order of 大约,左右,约与……相同(似),
达到……数量(= in the order of)
11. FM abbr. (略语)调频(frequency modulation)
自动化专业英语
·4·
·4·
12. tuner [5tju:nE] n. 调谐器,调谐电路,调音者,定弦者
13. moderately [5mCdEritli] adv. 适度地,稳健地
14. oscilloscope [C5silEskEup] n. [物]示波镜,示波器,示波管
15. voltmeter [5vEult7mi:tE(r)] n. 伏特计,电压表
16. milliwatt [5miliwCt] n. 毫瓦
17. milliampere [7mili5AmpZE] n. [电]毫安培
18. a.c. abbr. (略语)交流电(alternating current)
19. gain [^ein] n. 增益,财物的增加,利润,收获
vt. 得到,增进,赚到,vi.获利,增加
20. voltage gain 电压增益
21. impedance [im5pi:dEns] n. [电]阻抗,全电阻
22. resistor [ri5zistE] n. [电] 电阻,电阻器
23. valve [vAlv] n. 阀,活门,气门,[英]电子管,真空管(心脏)
瓣膜,(贝类的)壳瓣
24. tube [5tju:b] n. 管,管子,[英]地铁,<美>电子管,显像管
25. bipolar [bai5pEulE] adj. 双极的,有两极的,两相的
26. FET abbr. (略语)场效应管(Field-effect transistor)
27. J-FET J型场效应管
28. N-channel N沟道
29. inverting [in5vE:tiN] adj. 反相的,倒相的
30. boost [bu:st] vt. 推进,增加,增进,升压,拔高,改善
n. 上推,增加,提高,帮助,鼓舞
31. triode [5traiEud] n. [电子]三极管,真空三极管
32. op-amp abbr. (略语)运算放大器(operational amplifier)
33. current [5kQrEnt] adj. 当前的,通用的,流通的,草写的,最近的
n. 涌流,趋势,电流
34. in advance 提前,事前,预先
35. simultaneously
[simEl5teiniEsly; (?@) saim-]adv. 同时地
36. convention [kEn5venFEn] n. 大会,会议,协定,条约,协议,契约,
习俗,惯例
37. overall power 总功率
38. applied [E5plaid] adj. 应用的,实用的,施加的,外加的
39. acoustical [E5ku:stik(E)l] adj. 听觉的,声学的
40. consequence [5kCnsikwEns] n. 结果,[逻]推理,推论,因果关系,
重要的地位
41. sensor [5sensE] n. 传感器,灵敏元件
42. stimulus [5stimjulEs] n. 刺激,刺激物,促进因素[复数]stimuli
43. buffer [5bQfE] n. 缓冲器,缓冲物,缓冲区
ch01.pdf
278.38 KB, 下载次数: 43 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-1-2 04:12:09 | 显示全部楼层
推荐一下,版主继续努力!推荐一下,版主继续努力!
发表于 2008-1-3 19:25:16 | 显示全部楼层
xiee xie aaa
发表于 2008-1-9 22:54:51 | 显示全部楼层
谢谢分享
头像被屏蔽
发表于 2008-2-27 14:17:47 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
头像被屏蔽
发表于 2008-3-3 19:59:57 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-3-22 05:41:15 | 显示全部楼层
谢谢,收藏了
发表于 2008-4-5 10:48:56 | 显示全部楼层
好的,我英语台差了
发表于 2008-4-5 11:09:10 | 显示全部楼层
:loveliness: :loveliness: :loveliness:
发表于 2008-4-9 11:15:16 | 显示全部楼层
我看的脑袋都晕了
GMT+8, 2025-9-18 13:21 , Processed in 0.021739 second(s), 7 queries , Gzip On, Redis On.
