查看: 13739|回复: 41
[求助] 找書: Power Electronic Converters Modeling and Control
发表于 2018-3-12 19:16:55 | 显示全部楼层 |阅读模式
找書: Power Electronic Converters Modeling and Control with Case Studies
Authors: Bacha, Seddik, Munteanu, Iulian, Bratcu, Antoneta Iuliana
Modern power electronic converters are involved in a very broad spectrum of applications: switched-mode power supplies, electrical-machine-motion-control, active power filters, distributed power generation, flexible AC transmission systems, renewable energy conversion systems and vehicular technology, among them.
Power Electronics Converters Modeling and Control teaches the reader how to analyze and model the behavior of converters and so to improve their design and control. Dealing with a set of confirmed algorithms specifically developed for use with power converters, this text is in two parts: models and control methods. The first is a detailed exposition of the most usual power converter models:
·        switched and averaged models;
·        small/large-signal models; and
·        time/frequency models.
The second focuses on three groups of control methods:
·        linear control approaches normally associated with power converters;
·        resonant controllers because of their significance in grid-connected applications; and
·        nonlinear control methods including feedback linearization, stabilizing, passivity-based, and variable-structure control.
Extensive case-study illustration and end-of-chapter exercises reinforce the study material.
发表于 2018-3-15 10:34:54 | 显示全部楼层
2014 Power Electronic Converters Modeling and Control_ with Case Studies.pdf (9.38 MB , 下载次数: 292 ) 回复 1# Capricorn0115
 楼主| 发表于 2018-3-15 19:19:36 | 显示全部楼层
回复 2# xinlianxin
太神了~謝謝
发表于 2018-3-16 10:27:17 | 显示全部楼层
谢谢提供
发表于 2018-3-20 20:03:43 | 显示全部楼层
太强大了,谢谢
发表于 2018-3-22 22:17:09 | 显示全部楼层
Good.
发表于 2018-3-22 22:27:27 | 显示全部楼层
谢谢楼主分享
发表于 2018-3-27 10:03:58 | 显示全部楼层
谢谢分享
发表于 2018-3-27 14:10:57 | 显示全部楼层
Good.
发表于 2018-3-27 15:20:41 | 显示全部楼层
Good.
GMT+8, 2025-12-14 03:33 , Processed in 0.021014 second(s), 4 queries , Gzip On, Redis On.
