查看: 2524|回复: 6
[招聘] Marvell美满电子上海/成都/合肥多职位招聘
发表于 2015-12-18 14:00:36 | 显示全部楼层 |阅读模式
如感兴趣,欢迎投递简历至china-hr-staffing@marvell.com,邮件标题格式为“应聘职位名称-姓名-eetop”。
1. Senior ASIC Verification Engineer
Description:
- Candidates will be engaged in module-level and SoC verification.
- Candidates will individually develop test plan, test bench, and test cases according to the IP/SoC design spec.
- Co-simulation with reference models and audition of code and function coverage.
- Gate-level simulation with SDF annotation.
- Team up with RTL designers and software team to deliver bug-free IPs as well as the whole chip.
Qualifications
- Master degree in Electronics Engineering or above.
- 3+ years industrial experience in IC verification experience, successful tape-out experience is a plus.
- Proficiency in Verilog and SystemVerilog is MUST. Advanced verification methodology such as OVM or UVM experience is a plus.
- Self-motivation and team-work spirit is strongly required.
- Good at communicating across multi-function teams
2. Software Engineer
Description:
In this position, you will be involved in the Camera related software development for Tablet platform. Responsibilities include Camera driver/middleware/application development, performance optimization and system integration, etc.
Qualification:
- Having a M.Sc., B.Sc or Ph.D. level degree in Computer Sciences or EE, Telecommunications, Electronics, Automation or other related fields. At least 3 years working experience.
- Expert on TCP/IP, HTTP, SIP protocol
- Expert on multimedia, include video and audio
- Familiar with C, C++, Java Coding
- Familiar with Linux system
- Good knowledge on cellular protocol knowledge is a plus
- Good English, both verbal and written
- Strong sense of responsibility and team work spirit.
Prefer candidates with the following:
- Experience of developing in ARM platform.
- Experience of commercial product development.
- Hardware debug tools use such as multimeter, oscilloscope and logic analyzer
- Familiar with Linux kernel and having debug experience under Linux environment.
- Familiar with multimedia framework under embedded Linux environment
- Familiar with Android system and having develop/debug experience
3. Senior Software Engineer
Description:
- Strong Linux, GCC and C programming experiences
  Or Strong JAVA and JS programming experiences
- Familiar with SoC BSP or platform level developments
  Or Familiar with Android platform application software and Android’s UI static and dynamic layout developments
- Hands-on workings experiences on STB, Networking, Home Automation, etc..
Qualifications
- Bachelor or Master Degree in computer science or electrical engineering
- At least 3 year hands-on programming experiences on Android and Java, or C/C++ on embedded system
- Knowledge about semiconductor and consumer industry;
- Good customer relationship skill
4. Firmware Engineer
Description:
This candidate needs to work with QA manager/leader for all phases of test, including planning, test case designing, execution and quality management. Help developer to reproduce issues and analyze the root cause. Setup and maintain the build machine and the auto testing system.
Qualifications:
-B.S. in Computer Science, Computer Engineering, Electrical Engineering, or equivalent with 3+ years engineering experience
-Candidates need to be experienced in both host and embedded testing, experienced in Windows and/or Macintosh testing and driver testing, UI testing, and algorithm test.
-Candidates must have a proven track record as a host and embedded product tester for minimum of 3 years. Candidates need to have development experience in .NET, Perl, C++/C#, Windows API, DLLs, etc. Additionally, experience in Macintosh host software development would be a plus.
-Candidates will also need strong English communication skills, strong tech writing, self starting & ability to work in team environment.
发表于 2015-12-19 10:19:10 | 显示全部楼层
合肥还有marvell的分部呀,啥职位在招聘?关注一下
发表于 2015-12-19 10:43:09 | 显示全部楼层
期待Marvell重生
 楼主| 发表于 2015-12-21 17:28:19 | 显示全部楼层
回复 2# qingwatiaowu
您好,合肥现在在招软件工程师职位,如感兴趣,欢迎投递简历哦~
 楼主| 发表于 2015-12-23 10:46:24 | 显示全部楼层
回复 3# larkforsure
    谢谢亲的关注和鼓励~
发表于 2015-12-23 14:29:05 | 显示全部楼层
可惜呀,做硬件
 楼主| 发表于 2015-12-25 11:17:39 | 显示全部楼层
回复 6# qingwatiaowu
    您好,我们公司硬件、软件岗位都有哦,欢迎继续关注Marvell后续岗位发布,谢谢~
GMT+8, 2025-7-15 12:24 , Processed in 0.022290 second(s), 8 queries , Gzip On, MemCached On.
