查看: 6286|回复: 2
[原创] HDMI to LVDS 桥接芯片 ADV7613
发表于 2015-11-27 12:17:46 | 显示全部楼层 |阅读模式
优势和特点
Single-input HDMI receiver with dual channel LVDStransmitter outputs
HDMI receiver support
148.5 MHz maximum TMDS clock frequency
High-bandwidth Digital Content Protection (HDCP) 1.4 support with internal HDCPkeys
Adaptive HDMI equalizer
5 V detect and hot plug assert for HDMI port
Extended colorimetry, including sYCC601, Adobe RGB, Adobe YCC 601, xvYCCextended gamut color
LVDS transmitters
Dual channel 24-bit OpenLDI interface
Supports 6-bit and 8-bit nonbalanced OpenLDI or 8-bit video electronicsstandards association (VESA) formats
Audio support including high bit rate (HBR) and DirectStream Digital (DSD)
S/PDIF (IEC 60958-compatible) digital audio support
see data sheet for additional features
产品分类
音频和视频
HDMI接收器
产品详情
The ADV7613 is ahigh quality, low power, single-input HDMI to LVDS display bridge. Itincorporates an HDMI capable receiver that supports up to 1080p, 60 Hz.
The HDMI porthas dedicated 5 V detect and hot plug assert pins. The HDMI receiver alsoincludes an integrated equalizer that ensures the robust operation of theinterface with long cables.
The ADV7613 hasan audio output port for the audio data extracted from the HDMI stream. HDMIaudio formats include super audio CD (SACD) via Direct Stream Digital® (DSD)and HBR. The HDMI receiver has an advanced mute controller that preventsaudible extraneous noise in the audio output.
The ADV7613contains a component processor (CP) that processes the video signals from theHDMI receiver. It provides features such as contrast, brightness and saturationadjustments, STDI detection block, free run, and synchronization alignmentcontrols.
The LVDS encodercan package data into 6-bit or 8-bit non-dc balanced OpenLDI mapping or 8-bitVESA mapping. The ADV7613 can output 24-bit OpenLDI data via dual-channel LVDStransmitters, up to a maximum resolution of 1080p, 60 Hz received at the input.The maximum output clock supported by a single LVDS output port is 92 MHz. TheADV7613 is offered in an automotive grade and a consumer grade. The operatingtemperature range is −40°C to +85°C.
Fabricated in anadvanced CMOS process, the ADV7613 is provided in a 9 mm × 9 mm, 100-ballCSP_BGA, RoHScompliant package.
Applications
Projectors
Automotive infotainment headunits
Automotive infotainment displays
Digital signage
PHONE:13480757143  QQ:794843349
发表于 2016-2-6 04:53:05 | 显示全部楼层
很好的资料!
发表于 2018-3-20 14:13:01 | 显示全部楼层
回复 1# blackboat_2008
    rere, dingding.....
GMT+8, 2025-12-5 16:29 , Processed in 2.065860 second(s), 3 queries , Gzip On, Redis On.
