查看: 12590|回复: 13
ic615仿真 Error (ADE-3036)
发表于 2013-6-27 18:45:30 | 显示全部楼层 |阅读模式
[求助] Error (ADE-3036)
ic615仿真时候。点击绿色按钮 就提示下面错误,无法运行。哪位知道这个咋回事?谢谢 啊
ERROR (ADE-3036): Errors encountered during simulation. The simulator run log has not been generated.
Possible cause could be an invalid command line option for the version of the simulator
you are running. Choose Setup->Environment and verify that the command line options
specified in the userCmdLineOption field are supported for the simulator.
Alternatively, run the simulator standalone using the runSimulation file in the netlist
directory to know the exact cause of the error.
发表于 2013-6-27 19:50:10 | 显示全部楼层
用命令行仿一下试试
发表于 2014-2-7 08:58:47 | 显示全部楼层
I too have the same problem... please help
发表于 2014-2-10 09:59:49 | 显示全部楼层
回复 1# spectre.rf
   Has it got solved.. it got solved for me
发表于 2014-2-14 11:33:42 | 显示全部楼层
I have no idea.
发表于 2014-12-27 19:59:30 | 显示全部楼层
到simulation文件夹下,~/simulation/...//spectre/schematic/netlist/ 运行:
./runSimulation
/EDA/cadence/MMSIM141/tools.lnx86/spectre/bin/64bit/spectre: error while loading shared libraries: libreadline.so.5: cannot open shared object file: No such file or directory
看看什么错误,上面那个是我的问题,缺少共享库
发表于 2015-1-5 20:22:34 | 显示全部楼层
32位的也是,缺少32位的库
发表于 2015-1-6 23:24:10 | 显示全部楼层
好好学习,天天向上。
发表于 2015-1-17 10:12:28 | 显示全部楼层
回复 6# fangtaocome
   库文件安装上了,依然报错,怎么办
发表于 2015-9-15 02:25:00 | 显示全部楼层
回复 9# wmchpu
    装上这个库之后还是同样的问题,请问你解决了吗?
GMT+8, 2025-11-2 22:29 , Processed in 0.026291 second(s), 3 queries , Gzip On, Redis On.
