楼主: qfliuyang
Sentaurus 2010安装及破解指导详细修正版(绝对可用)与优质教程
发表于 2013-5-22 23:34:44 | 显示全部楼层
已经装上了,不过还有两个问题没有解决,一个是自动设置开机启动license文件不行,还有就是tecplot不知道为什么用不了
发表于 2013-5-31 14:01:47 | 显示全部楼层
非常感谢楼主
发表于 2013-7-4 00:11:01 | 显示全部楼层
谢谢楼主分享!
发表于 2013-7-8 22:42:51 | 显示全部楼层
大牛, 问一下我是win7 的系统,下载vm player 这个虚拟机才80mb, 装在这上面可以不?
发表于 2013-7-10 15:36:28 | 显示全部楼层
非常感谢,sentaurus要学好久的感觉
发表于 2013-7-26 17:00:17 | 显示全部楼层
这个一个要赞的
发表于 2013-7-27 15:26:02 | 显示全部楼层
回复 1# qfliuyang
License lookup failed: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Feature:       swb_all
Server name:   localhost.localdomain
License path:  27000@localhost.localdomain
FLEXnet Licensing error:-15,570.  System Error: 115 "Operation now in progress"
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com"..
        * feature is "swb_all"
        * version is "2009.06"
        * STROOT is "/usr/synopsys/D_2010.03/bin/.."
        * hostname is "localhost.localdomain"
        * display is "/dev/pts/5"
        * user is "root"
这是什么原因,有人知道吗
 楼主| 发表于 2013-7-28 22:55:08 | 显示全部楼层
回复 23# xt8843
应该是缺一个库,注意看错误提示
 楼主| 发表于 2013-7-28 22:58:12 | 显示全部楼层
回复 31# 叶风舞
   "Operation now in progress"。。。 先把所有license都lmdown掉,再lmgrd
发表于 2013-7-29 16:42:10 | 显示全部楼层
好东西 赞一个
GMT+8, 2025-6-23 00:23 , Processed in 0.022665 second(s), 9 queries , Gzip On, MemCached On.
