查看: 10479|回复: 29
[求助] 帮忙下IEEE论文 Design of novel bootstrap driver used in high power BUCK
发表于 2010-5-28 20:01:46 | 显示全部楼层 |阅读模式
http://ieeexplore.ieee.org/search/freesrchabstract.jsp?tp=&arnumber=5351169&queryText%3Dbootstrap+and+converter%26openedRefinements%3D*%26searchField%3DSearch+All
Design of novel bootstrap driver used in high power BUCK converter
Zekun Zhou; Xing Ming; Bo Zhang; Zhaoji Li;
ASIC, 2009. ASICON '09. IEEE 8th International Conference on
Digital Object Identifier: 10.1109/ASICON.2009.5351169
Publication Year: 2009 , Page(s): 1165 - 1168
IEEE Conferences
Abstract  |  Full Text: PDF (2350 KB)
A novel bootstrap driver suitable for high power buck converter is presented in this paper. With the help of
bootstrap driver, the P type power MOSFET used in conventional buck converter can be replaced by N type power MOSFET
in order to optimize efficiency and area. The proposed bootstrap driver, abandoning conventional level shift
circuit, can work properly in a wide power supply range with sufficient protection. The bootstrap driver has been
validated with UMC 0.6-¿m BCD process based on a monolithic voltage-mode BUCK converter capable of driving up to 3
A loads with supply voltage from 8 to 30 V. Simulation results demonstrate that the power efficiency is over 84% for
load current from 1 A to 3 A, and the buck converter can operate properly under all the application conditions. Read
More»
发表于 2010-5-31 08:46:32 | 显示全部楼层
怎么連接也沒有?叫人家幫你下載?
发表于 2010-6-6 16:59:57 | 显示全部楼层
也想知道。
发表于 2011-4-26 15:02:23 | 显示全部楼层
同求相关的PAPER!忘前辈们不吝分享!谢谢了!
发表于 2011-7-16 21:50:43 | 显示全部楼层
刚刚网友帮忙上传了
发表于 2011-7-16 22:28:32 | 显示全部楼层
看附件
novel_bootstrap_driver_used_in_high_power_BUCK_converter.pdf
2.3 MB, 下载次数: 337 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2011-7-26 23:52:40 | 显示全部楼层
不错不错!!!!!
发表于 2012-5-16 16:38:03 | 显示全部楼层
好东西啊 正需要
发表于 2012-5-21 09:03:49 | 显示全部楼层
Good sharing!!!!
发表于 2012-8-26 14:56:30 | 显示全部楼层
Good sharing!!!!
GMT+8, 2025-11-15 03:29 , Processed in 0.027689 second(s), 6 queries , Gzip On, Redis On.
